Engine swap? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2008, 09:13 PM   #1 (permalink)
View z4ns4tsu's Photo Gallery
gen 7 Engine swap?
I'm wanting to kick up my '05 GT for circuit racing, and I know that I'm going to need a better engine to do it. What do you suggest I look at getting? I don't know a lot about Toyota's performance engines as I've mostly worked with big-block V8s and V6s before. I'm thinking that I'll go with a 2ZZ-GE plus trans from a gen 7 GT-S (probably 2003 or later to avoid the lift bolt TSB issue). I'll start with a CAI, but I'd like to eventually blow it with a supercharger. I figure that I'll need a new ECU and all the suspension help that I can get my hands on to keep it rigid, but I haven't taken the time to figure out the specifics yet.
What I'd like to know is, what are the best brands to look at? Am I right in thinking that the 2ZZ is about the best engine for what I'm looking at doing? I know that the 3S-GTE is really popular on these forums, so what are the specific benefits of it over a blown 2ZZ?
On a related note, who makes over-sized pads and rotors that I could add now? I'm getting 17" Sport Max Type 008s in the next few weeks and I want to change those at the same time.
z4ns4tsu is offline   Reply With Quote
Old 04-02-2008, 12:06 PM   #2 (permalink)
jlspec's Avatar
View jlspec's Photo Gallery
The 2ZZ-GE would be good enough when turbo/supercharged for what your doing plus it's lighter, but if you looking at which engine has the most potential then the 3S-GTE is your bet. The 3S-GTE from stock can handle much more power plus when modify is one the most powerful 4 cylinder built. If money is not an issue, then getting a either a GEN 2or GEN 3 3S-GTE (preferably the GEN3) would be your best bet. The Castrol Supra uses a modify 3S-GTE due to being lighter then a 2JZ but offers power levels close to it.
1990 Celica Turbo All-Trac
jlspec is offline   Reply With Quote
Old 04-09-2008, 04:04 PM   #3 (permalink)
View CelicaFreak's Photo Gallery
I want an engine swap on my celica 00 GT.
Are those two engines the only options i have? I want as much power as possible. Do you guys have any suggestion?
CelicaFreak is offline   Reply With Quote
