Cylinder Head Bolt Torque - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-04-2008, 11:17 PM   #1 (permalink)
View 87gtcelica's Photo Gallery
car: 1987 Toyota Celica GT 2.0 Automatic
Hello, can someone verify below that this is correct sqeuence and torque for 1987 Celica GT 2.0 Automatic?
Thank you.
1. tighten all to 22 FT. LBS.
2. tighten an additional 90 degrees
3. tighten an additional 90 degrees
sequence:
(8) (7) (1) (3) (9)
(10) (4) (2) (5) (6
87gtcelica is offline   Reply With Quote
Old 04-06-2008, 02:01 AM   #2 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
I can't say for sure on your particular engine but most 4 cylinder engines swap 6 and 7.
(8) (6) (1) (3) (9)
(10) (4) (2) (5) (7)
The basic idea is to start at the centre and work your way out to the edges in rings, criss-crossing from side to side and left to right.
This helps spread the metal out evenly.
If you start from the outside and work inwards then you squeeze the metal into the centre and then you are left with some excess that has nowhere to go.
- Stepho
stepho is offline   Reply With Quote
