anyone know what this is?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2008, 12:28 AM   #1 (permalink)
95 COROLLA's Avatar
View 95 COROLLA's Photo Gallery
Gen5 anyone know what this is??
just bought a 90 GT-S and i notice when i accelerate above 4,500RPM you get a whistling sound, my friends Mazda protage makes the same sound under accleration above the same RPMs he said that its because the car was drivin in to the high RPMs alot when it was new causing the air box to shrink and whistle or its the main vacuum line, now i know the air box probably isent the problem because there is no vaccum in the air box. anyways if anyone else has seen this or know what it might be and could shed some light on it that would be sweet thanks guys
Dan
95 COROLLA is offline   Reply With Quote
Old 04-20-2008, 02:08 AM   #2 (permalink)
View Toy_Celi's Photo Gallery
Dan
Is it an allwheel drive? because that could be a turbo if its the 3SGTE...
Toy_Celi is offline   Reply With Quote
Old 04-20-2008, 09:55 AM   #3 (permalink)
95 COROLLA's Avatar
No its 2.2L N/A definitly not a turbo sound
Old 04-20-2008, 04:15 PM   #4 (permalink)
Noob :-)
View ST185's Photo Gallery
That's BS.
If it's RPM relate, I'd check the belt/pulley first.
If you are sure that it's the wind/air noise, check vacuum lines and check if there is any exhaust leak.
Also, if it is speed related, it wouldn't hurt to see if the side mirrors fit OK.
They'll make noise if they are not fit properly.
93 ST185
ST185 is offline   Reply With Quote
Old 04-23-2008, 06:13 PM   #5 (permalink)
MERMAiD666's Avatar
View MERMAiD666's Photo Gallery
Hmmm... Whistling... Sounds like maybe the throw out bearing?
MARK OF THE FREAKiN' BEAST
\m/(><)\m/
MERMAiD666 is offline   Reply With Quote
Old 04-23-2008, 06:44 PM   #6 (permalink)
95 COROLLA's Avatar
No, I'm leaning towards some kind of vacuum leak probably a hose or broken valve I'm going to take a vacuum gage to it at work tomorrow if i find anything i will post it
Old 04-24-2008, 12:27 AM   #7 (permalink)
View aych's Photo Gallery
um, check the window seal mounting =P i got my windows replaced for the first time on my camry in 16 years and well, they mis mounted by 1 degree, now i get whistling depending on how the wind is blowing and how fast i'm driving
aych is offline   Reply With Quote
Old 04-26-2008, 04:17 AM   #8 (permalink)
View Tezmaster's Photo Gallery
your all funny if you have GTS model it should have t-vis lol after 4300 rpm the butterfly valuves open then bamm u hear it i do in my celica ! gts 1989
Tezmaster is offline   Reply With Quote
Old 04-26-2008, 12:05 PM   #9 (permalink)
Noob :-)
90 GTS got 5SFE, no TVIS in there.
93 ST185
Old 04-28-2008, 11:16 PM   #10 (permalink)
95GT's Avatar
View 95GT's Photo Gallery
My 91 did that and it was a vacuum line. Mechanic replaced cat and problem whistle went away.
95GT is offline   Reply With Quote
Old 05-13-2008, 07:32 PM   #11 (permalink)
aolteach
aolteach's Avatar
View aolteach's Photo Gallery
My 92 5S-FE whistles, but it's coming from the rear of the car. With the hood down, I stand outside the car, but put my foot inside and on the gas peddal and rev it way up.
I believe my prob is in the CAT and therefore it sounds like it's coming from the rear of the car. Or possibly the muffler. Either way, it's in the exhaust system in my case.
Interesting post 95GT. This one has bugged me for years now. This summer that CAT is getting gutted.
aolteach is offline   Reply With Quote
Old 05-13-2008, 08:29 PM   #12 (permalink)
View EK94LIFE's Photo Gallery
I know that some celicas whistle past a certain point is there a crack in your intake piping anywhere? If its that rubber piping like mine and has a crack it sucks in through the crack at a certain rpm and sounds like when you blow through one of those rippled straws you get in those reusable cups you get at the fair...
EK94LIFE is offline   Reply With Quote
