20R/22R engine help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2008, 01:46 AM   #1 (permalink)
JimiRain's Avatar
View JimiRain's Photo Gallery
Canada 20R/22R engine help
I recently purchased a 2xR engine. My problem is the middle digit in the name is faded away and I cant figure out which one it is. Can someone please tell me how to identify which engine I have.
71' Celica S/T
89' Dodge Daytona
JimiRain is offline   Reply With Quote
Old 04-20-2008, 02:04 AM   #2 (permalink)
View Toy_Celi's Photo Gallery
is it a 4 cylinder? the 22R is a 4 banger...
Toy_Celi is offline   Reply With Quote
Old 04-20-2008, 03:29 AM   #3 (permalink)
DCM
One with the farce
View DCM's Photo Gallery
^ yeah, but so is the 20R.
JR - is the engine together, or is the intake off it, or anything else? No pics? The intake ports on the 20R are round, and the carb has a round opening where the air cleaner fits on.
The 22R has square-ish intake ports and the carb opening has a more rectangular shape to it.
DCM is offline   Reply With Quote
Old 04-20-2008, 07:12 AM   #4 (permalink)
73GTV
73GTV's Avatar
View 73GTV's Photo Gallery
Wow, I thought that all Toyota Blocks where stamped with the Model number in the Block casting on a flat surface for easy identification. Plus you can always take to block part number and call it into a Toyota parts counter to see what comes up within the system. At least it can narrow down the production years for easier reference.
73GTV is offline   Reply With Quote
Old 04-20-2008, 08:27 PM   #5 (permalink)
DCM
One with the farce
Some of the stamping isn't very clear, which is what I'm assuming is the case here.
Old 04-20-2008, 09:07 PM   #6 (permalink)
73GTV
73GTV's Avatar
Well your information on the type fuel system should help with that ID as you stated earlier. But the Block part number is always the way to make sure via the factory part numbers. Sorry, I forget that these engines are subject to exterior damage due to road salt. Sorry Just moved North from Florida and I forgot about rust and the effects of salt.
Old 04-21-2008, 12:40 AM   #7 (permalink)
DCM
One with the farce
I do agree that the part number is the best method. It is unfortunate that the ID pad on the 20/22R's is almost flat and dirt and moisture can collect there. Up here in BC they use a lot of salt, too.
Old 04-21-2008, 01:07 AM   #8 (permalink)
bilt not bot
View shonuff's Photo Gallery
there is also a sticker on the dizzy and coil and it will say "2xr"
got pics?
www.youtube.com/nuffbilt
shonuff is offline   Reply With Quote
Old 04-21-2008, 01:27 AM   #9 (permalink)
DCM
One with the farce
The 22R distributor will fit the 20R, that's not a fool proof method.
Old 04-21-2008, 06:48 AM   #10 (permalink)
RA28 + MX73
View stepho's Photo Gallery
Here is a summary of the 20R and 22R and the differences between them.
http://members.iinet.net.au/~stepho/eng20r.htm
Quite often the ID number (which should start with 20R or 22R) can be cleaned up with a bit of industrial cleaner.
Or rub it with some fuel soaked cloth (to remove grease) and then some sandpaper (the flat metal becomes shiny while the dark grit stays embedded in the numbers).
Luckily, both engines will fit your '73 Celica.
- Stepho
stepho is offline   Reply With Quote
Old 04-21-2008, 08:44 PM   #11 (permalink)
JimiRain's Avatar
Thanks everyone. After removing the exhaust manifold i found 20R stamped in the block.
71' Celica S/T
89' Dodge Daytona
Old 04-22-2008, 06:25 PM   #12 (permalink)
73GTV
73GTV's Avatar
You are welcome, Send pictures when you get to a stopping point so we enjoy your progress. Keep wrenching and help breath life into old metal.
Old 04-25-2008, 01:00 AM   #13 (permalink)
WOOT! i love rolling in old cars! got my 88, 91, and a few new cars lol
