whats the difference between the st and the gt engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2008, 08:50 PM   #1 (permalink)
lilsotojd's Avatar
View lilsotojd's Photo Gallery
whats the difference between the st 3sfe and the gt 5sfe celica engine
lilsotojd is offline   Reply With Quote
Old 04-20-2008, 08:59 PM   #2 (permalink)
Noob :-)
View ST185's Photo Gallery
Larger displacement due to longer stroke and slightly larger bore.
3sfe = 1998cc and 5sfe = 2162cc
93 ST185
ST185 is offline   Reply With Quote
Old 04-20-2008, 09:15 PM   #3 (permalink)
lilsotojd's Avatar
will a 5sfe fit on a 3sfe trany
Old 04-21-2008, 11:55 AM   #4 (permalink)
Gameroom cash: $147537
Yes. When you do the swap, keep all the electrical from the 3S-FE. Reuse everything with a wire from the 3S. All you need from the 5S is the block and head. All at least change all the seals, timing belt and water pump while the engine is out.
Old 04-21-2008, 12:35 PM   #5 (permalink)
jlspec's Avatar
View jlspec's Photo Gallery
If you talking about the ST engine in the 90-93 Celica ST then it's a 4A-FE not a 3S-FE. The 5S-FE came in the 90+ Celica GT/GT-S while the 3S-FE was in the 87-89 Celica ST/GT the 86 ST uses the 2S-E.
1990 Celica Turbo All-Trac
jlspec is offline   Reply With Quote
Old 04-21-2008, 04:02 PM   #6 (permalink)
^It depends on where he got the ST or ST engine.
4A-FE 1.6L, 3S-FE, 2.0L, 5S-FE 2.2L.
