Code p01717: time for new MAF? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2008, 03:49 PM   #1 (permalink)
View iam7head's Photo Gallery
2000 gts celica auto
So my sister's celica is throwing a cel(p0171: system too lean) while she was driving on the freeway(freeze data~60mph) and it's a soft code. The car felt jerky(rpm laggy, power serge, etc, all the good symtom of bad maf)
i cleaned the MAF and check all the vaccum lines, erase the code and the same code came back like a week later. So what's the next step? new maf
new o2 sensor?
thanks all
00 Honda S2000 ap1 2.0(daily)
90 Mazda Miata na 1.6(beater)
02 Honda Accord turbo 2.3(parted and sold)
89 Acura legend L 2.7(sold)
iam7head is offline   Reply With Quote
Old 05-14-2008, 12:56 PM   #2 (permalink)
6th gen master
View hatchy_gt-s's Photo Gallery
does the car have a k&n air filter or a filter that requires oil if so most likely a MAF if you can check plugs and wires and injectors the easiest way to do that is to take a stethoscope to the injectors if you cant take a volt meter or test light to check pulsing (check the ground side of the injector)
if these are all good its most likely going to be the MAF o2's rarely go out.
if you can check the o2 if it is good you will see it travel between 2 and -1.5v
if you can keep us updated
thanks
hatchy_gt-s is offline   Reply With Quote
Old 06-13-2008, 05:45 AM   #3 (permalink)
i cleaned it again very good this time and CEL stay off for months now, the previous owner probably have some sort of aftermarket filter, but it's all good now
thanks all
Old 06-13-2008, 09:16 AM   #4 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
When you clean the sensor wires make sure your cleaning the right ones. The wire you can see easily at the bottom of the sensor is the intake air temp wire which is not the one that needs to be cleaned. The air flow sensing wires are actually up inside the tube housing. Just thought id mention it since ive seem a few people make that mistake. You can see them if you look in there with a flashlight.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
