Ok, first of all, if your exhaust manifold can't tighten down all the way, it might leak. So that's a problem. But, fixing the exhaust manifold won't solve the problem of burning oil, if your engine does burn oil.... Anyways, here are some ideas on how to fix the thread on your exhaust manifold to tighten it down.
First of all, check to see if the bolt needs to be replaced. If it's just the bolt that is threaded - and that might be the case - you can buy a new bolt for probably less than a dollar at a hardware store like Ace. Then your problem is fixed cheap. So first of all, I would get a new bolt and see if that works.
If the thread of the actual hole is messed up, this is a little more problematic. There are a number of solutions for fixing a threaded hole. You can buy a heli-coil kit, I know auto parts stores sell them for about 20 or 30 bucks. Personally, I have never used a heli-coil kit, so I don't know how well they work. What I do to fix thread holes is to buy a "tap" at a hardware store. A tap is a special bit that cuts a new thread into a hole, and they usually cost less than 10 dollars. You will need to get a tap that is only a couple of mm larger thread than the hole - MAKE SURE THE TAP IS NOT TOO BIG! Drill out a new thread with the tap, buy a new bolt to fit the new thread, and you can now get the bolt real nice and tight.
