01 Celica GTS - Prem, MidGrade or Regular Octane - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-13-2008, 10:02 AM   #1 (permalink)
View hlfrzovr's Photo Gallery
I'm looking at buying a 2001 Celica GTS w/auto trans & 90K miles. Everything I've read says that premium fuel is required/recommended with the GTS. Does anyone have a GTS and use MidGrade or regular fuel? The idea of buying a car that uses Premium fuel with today's gas prices isn't very appealing.
hlfrzovr is offline   Reply With Quote
Old 05-14-2008, 01:40 PM   #2 (permalink)
View JustChris's Photo Gallery
premium only, or else you'll get engine knock.
JustChris is offline   Reply With Quote
Old 05-14-2008, 05:50 PM   #3 (permalink)
6th gen master
View hatchy_gt-s's Photo Gallery
just to let you know you can use regular it wont hurt the car
and you wont automatically get engine knock its only 90k so regular or mid wont hurt
hatchy_gt-s is offline   Reply With Quote
Old 05-20-2008, 05:44 PM   #4 (permalink)
Yes it will, don't give him stupid advice just because you aren't intelligent.
Old 05-21-2008, 04:09 PM   #5 (permalink)
6th gen master
ok ya i dont know what im talking about
so if i dont put high octane in my car it will knock because the last time i checked none of my cars dont knock
i only work on cars for a living so the next time you insult the person trying to give information learn something yourself
Old 05-21-2008, 04:53 PM   #6 (permalink)
Box driving
View Boxedin's Photo Gallery
Seeing how it is high compression engine you should use high octane for optimal performance. If you decide to use lower octane it will decrease performance, via computer settings to retard ignition timing, thus avoiding knock... Let me know if I can help with anything else.
08' Scion Xb 5 Speed -39K miles-
(2az-fe)
88' Toyota Celica All-Trac Turbo 5 Speed -97K miles-
(on blocks, car cover on, STABIL in the fuel tank, in storage)
07' Honda Fit 5 spd auto. 237k miles. (yeah believe it)
Boxedin is offline   Reply With Quote
Old 05-21-2008, 04:59 PM   #7 (permalink)
6th gen master
^ thank you for agreeing
Old 05-21-2008, 06:01 PM   #8 (permalink)
It will knock, go to newcelica.org for 7th gen questions, you guys are going to ruin your cars.
Old 05-23-2008, 11:52 AM   #9 (permalink)
XRSs'n
Corolla_reps's Avatar
View Corolla_reps's Photo Gallery
Mid grade wouldn't hurt....as long as you put Premuim grade once in a while it will not knock...i got an XRS Matrix...
TRDXRS...
Corolla_reps is offline   Reply With Quote
Old 05-28-2008, 12:41 PM   #10 (permalink)
ae92 gal
krissyae92's Avatar
View krissyae92's Photo Gallery
no worries, it wont knock. people think that the slightest change in gas makes a deifference. 87, 89 and 91 are almost the same.
krissyae92 is offline   Reply With Quote
Old 05-28-2008, 01:53 PM   #11 (permalink)
XRSs'n
87 and 91 is totally diff gas....as far as i can see 87 has more water based than premium gas therefore it will not help the engine progress power... 89 is mixed grade with premium is not as great but still mix with premium gas
TRDXRS...
Old 05-29-2008, 10:24 AM   #12 (permalink)
6th gen master
actually the only difference between the fuels is additives. the lower the octane the less additives it has to prevent knocking, fuel doesn't have more water in it seeing as water wouldn't be able to evaporate in the cylinder
Old 06-08-2008, 06:38 PM   #13 (permalink)
View streetrider's Photo Gallery
^^^^ I agree that 87 oct is not watered down. But how would water NOT evaporate in a cylinder where high temperature combustion is taking place? please elaborate.... Maybe I'm retarded when it comes to physics but I would think, any water present in the engine would instantly become steam and exit through the exhaust valve/s. Exactly like it would during water/methonal injection when being used as an anti detonation measure.
streetrider is offline   Reply With Quote
Old 06-08-2008, 08:42 PM   #14 (permalink)
6th gen master
because the speed of your cylinder and you injectors are moving so fast ie rpm's that it doesnt have time to and it slowly builds up
Old 06-08-2008, 10:15 PM   #15 (permalink)
Shuh, no way man! If H20 is introduced into the combustion chamber during combustion, it wil INSTANTLY VAPORIZE and exit with the normal exhaust gasses. It doesn't matter if the motor operates at 100,000 rpm. which is exactly why if you run water/methonal injection you don't drive around with puddles of water just chilling in your cylinders.
This is a different concept but I think that it reinforces my point. http://www.damninteresting.com/?p=467
