This is for a 1976 Celica 20R Manual Coupe.
Want to upgrade the distributor with a vacuum advance from a rotatory to an electronic. Need to replace the whole distributor, because I believe the current vacuum advance is not functioning properly. I think the ignition coil needs to be upgraded as well when doing this kind of upgrade, but not sure. Need help in picking a decent brand and specifics on what to order, and where. The ignition coil is what is confusing me, the watts and the ohms for a 20R engine, not to mention the spark plugs gaps can be set bigger...bigger to what?
Will be replacing the Asian stock carburetor to a Weber 32/36, (looking for fuel economy, will be a daily driver). Have heard that the Redline is not so good, but has the fuel economy of a 32/36 but the power of a 38, correct me if I'm wrong please.
Some info on car:
Has passed California smog.
Secondary throttle does not function while driving, so versus getting a reman Asian carb, going to hold out for a Weber 32/36. So as I understand it, the weber still needs a vacuum line to the vacuum advance on the distributor... or does it?
The distributor and ignition coil upgrade should also increase mpg. Is there something else I should be looking at getting with the
distributor and ignition coil?
Has new struts, shocks, brakes, head gasket, spark plugs and wires, heater coil, and over $500 in getting the wiring checked. Although there are still wires not hooked to anything, like to the thermostat sensor. The mechanic is functional to about 90% of getting things done, but then just flounders at the last 10%. Such as putting in new struts but then he puts the 30 year old rubber cracked mounts back on. He is putting the new mounts on as we speak, plus changing the transmission and U joint seals.
What is truly frustrating, is that after spending close to $2,000 in repairs, it was I who figured out the secondary throttle was not working. And it was I who, figured out how to temporarily fix this by making a spare spring grab the 2nd throttle as the main throttle was activating.
Going to put off, for now, a new cam, exhaust header, cat, pipes, muffler and such. Will figure out that cost versus an engine upgrade then decide. Remember, this will be a daily driver, but with some pep is all I need. Plus it's a California car.
Thanks in advance
Here are some pics: Yes that's a 77 20R carb on a 76 20R engine. It was also I who also figured out the vacuum lines for the EGR and AAP were wrongly hocked up.
