Jdm 3sfe
If you have a 1990-1993 Celica with a JDM 3SFE 2.0L swapped engine inside; the answer is yes it will fit. That engine is virtually identical to the 5SFE is except for some small details. Some of those details are the displacement being 2.0 instead of 2.2, slightly more horsepower with slightly less torque among other things. But the header / exauast and any other bolt on application for the 5SFE will work fine.
Make sure your engine is not the American verison of the 3SFE because that engine is signifiacantly less powerfull and I am not sure if you can use the Pacesetter exhaust with it. I also have never heard of an American 3SFE inside a 5th Generation Celica... hopefully you have the JDM.
