Possible Clogged Cat Converter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2008, 12:44 PM   #1 (permalink)
View Broslice's Photo Gallery
Gen6 Possible Clogged Cat Converter
I think my 95 celica gt has a clogged converter, it has a slight rotten egg smell when i whiff the exhaust. There is no noticeable performance loss.
Question: What causes a poisoned/clogged converter?
Question 2: If i replace it, will it just happen again?
Broslice is offline   Reply With Quote
Old 05-27-2008, 12:50 PM   #2 (permalink)
Gameroom cash: $147537
Cat don't really get clogged unless all you do is very short drive. Take the car out for a long drive on highway and see if it helps.
Cat will get broken. Its ceramic and if a stone hit it or you hit a big pot hole, it may shatter.
Old 05-29-2008, 11:31 AM   #3 (permalink)
Gen6
I have driven it on the highway for about an hour, there is a burnt rubber smell and i pop the hood and can see a small amount of a greyish smoke down below the cat converter.
Old 05-29-2008, 11:54 AM   #4 (permalink)
Got a leak? Did the engine cover under the car touched the exhaust?
You can remove the cat and check gasket and the ceramic. You should be able to see a grid inside.
