Clutch Pedal Sticking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2003, 07:05 AM   #1 (permalink)
View sritzau's Photo Gallery
I have a 93 Celica GTS and have recently had a problem with the clutch pedal sticking down. I tried bleeding the clutch but that has not helped. The problem seems worse on cold mornings. Any advice on this problem or the clutch system in general?
Thanks in advance,
Steve
sritzau is offline   Reply With Quote
Old 11-14-2003, 09:47 AM   #2 (permalink)
View Deep's Photo Gallery
93 had a cable clutch, have you tried adjusting the cable?
Deep is offline   Reply With Quote
Old 11-14-2003, 11:30 PM   #3 (permalink)
GT-i Crew
lcarocha's Avatar
View lcarocha's Photo Gallery
Cable clutch....? AFAIK all 4th-7th Gen Celicas use a hidraulic clutch system. I tried looking up anything clutch wire related on the Toyota EPC and nothing came up
Have you checked the clutch fluid level...? I'd bet it's the clutch slave cilinder thats already giving away so you probably are loosing some fluid; my advice is to buy the kit and service the unit, it's rather simple and it will only take an 1 hour or 1 1/2 hours tops other wise you'll wake up to no clutch sooner or later.
Luis C.
92 Celica GT-i (ST182)
2nd Gen 3S-GE
Caracas, Venezuela
http://www.cardomain.com/id/luis_c
lcarocha is offline   Reply With Quote
Old 11-15-2003, 06:23 AM   #4 (permalink)
I have checked the fluid level when bleeding the clutch. Problems in the slave cylinder could be the problem. It is definitely getting worse. Any idea where can I get the kit for servicing the slave cylinder?
Steve
Old 11-30-2003, 12:44 AM   #5 (permalink)
View Jman's Photo Gallery
I had similar problem with my 89 celica gts...i changed the master cyclinder and that did the trick
jerry
Jman is offline   Reply With Quote
Old 12-02-2003, 03:46 PM   #6 (permalink)
View 89AllTracTurbo's Photo Gallery
I had the same problem with my 89 AllTrac it turned out to be a leaking slave cylinder.
1989 Toyota Celica AllTrac...
2001 BMW 330i
89AllTracTurbo is offline   Reply With Quote
