coolant flush, spark plugs (iridium) manual trans oil. check air filter as well. Make sure the mechanic does a full shake down of the front wheels to inspect for loose or worn front end parts. Inspect brake hardware (anti-rattle clips) and perhaps re-grease the brake slide pins. Inspect the strut assemblys for seepage of hydraulic fluid. Lastly if not performed already re torque all crossmember and under carrage bolts. If you need anything else let me know.
08' Scion Xb 5 Speed -39K miles-
(2az-fe)
88' Toyota Celica All-Trac Turbo 5 Speed -97K miles-
(on blocks, car cover on, STABIL in the fuel tank, in storage)
07' Honda Fit 5 spd auto. 237k miles. (yeah believe it)
