Might look in newspapers, Craigslist, etc for someone totaling a Celica or Camry (used the same engine). Rebuilding even if doing it yourself is still costly unless going on the dirt cheap. Best to find a decent used engine that can be swapped with just a timing belt belt change (precaution), etc.
Check out Chilton and Haynes manuals,your local library may have manuals for checkout.
Keep in mind engines after around 1995 started to incorporate crank and cam sensors mounted on the front of the engine, plus other subtle differences.
