Choosing Right Industrial Lubricants
Most of us use some types of industrial lubricants regularly. If we use some oil to cycle paddles to run them smoothly, we use lubricants. The main function of lubricants is to remove friction between moving parts of two solid surfaces. But they also perform other functions such as removing wear, cleaning, preventing against rust & corrosion etc.
As we known that when two solid surfaces interact together it causes friction and friction causes heat. So, the use of industrial lubricants also cools the moving parts by transferring heat away as well reducing friction. This is why they are also termed as heat transfer fluids. A large amount of lubricating oils or fluids are consumed in industries like large and small scale metal working industries, automobiles, transportation, etc. The use of lubricants makes enable any machinery smooth running and provide longer life and ultimately saves money and time both.
There are several different types of lubricants which are used in industry for different purposes. Greases, lubricating pastes, Compressor oils, turbine oils, hydraulic oils, farming oils, metalworking fluids, etc are kinds of industrial lubricants which are used in industries for different purposes. But the main purpose of all these lubricants is same i.e. to reduce friction & wear. In metal working industries, a large amount of lubricating materials is also used for lubrication. Grinding fluids, cutting fluids, coolants, etc are example of metal working fluids.
The single largest application of lubricants is in the form of motor oils (also termed as engine oils) which are use in various types of internal combustion engines for the purpose of lubricating moving metal parts, inhibiting corrosion, and cooling the engine by carrying heat away from the moving metal parts. No one can think smooth and safe running of a vehicle without using lubricants such as motor oils, gear oils, greases, etc.
But while using lubricants for your industrial need you must opt for right types of lubricants. Choosing the right lubricants can be tricky task. Before selecting the proper lubricants you must consult suppliers who can assist you in choosing the proper lubricants in your application. There are several lubricant suppliers who design lubricants for the different industrial needs and applications using some additives for better performance.
But all lubricants must meet general technical requirements such as reducing friction, reducing heat, reducing wear, protecting against rust & corrosion, cooling, etc. But depending on your industrial needs or application you must choose lubricants which are specially designed for that application. Thus, we see that using right & proper industrial lubricants can provide your machinery longer life, better performance and ultimately can save both money and time for you.
