possible wiring problems?
I think theres something wrong with the wiring (actually im not sure). Because it started whenever I use my horn, after 2 horns the fuse blows and whenever I replace it it blows again. I have been using the right fuse. Then afterwhile my flasher lights stopped working as well. It was working for a bit in the beginning, it would blink then it would get stuck. I went to the mechanic didnt really had da time to look at it because I was getting my brakes done as well. He said that I might need to replace the flasher relay. So im not sure if I should get a new one or would this be a wiring problem. HELPPPPPP!!!
