How to remove antenna housing. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2008, 02:41 PM   #1 (permalink)
View EazyE17's Photo Gallery
Exclamation How to remove antenna housing.
2002 Celica GT
I was trying to unscrew the piece that the antenna screws onto and it broke off. Half of it is still inside. It is far enough in that I cant even try to unscrew the rest out. I tried taking out the whole piece its screwed into but didnt want to break something else off. Let me know how I can get to this and fix it. Greatly appreciated, thanks.
EazyE17 is offline   Reply With Quote
Old 07-30-2008, 02:57 PM   #2 (permalink)
I figured it out
In case anybody else has this issue: You remove inside cover from behind the right rear tail light. You can disconnect the wire just by pulling it loose. There was a little tape around mine. Then you can pull the antenna down which leaves just a hole. I purchased a new antenna from an auto parts store by my house for $10. All there was to do was plug the new antenna into where old one was pulled out and screw it on. A very easy fix.
