Sluggish at low RPM - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2008, 08:17 AM   #1 (permalink)
View Greaper_ca's Photo Gallery
Sluggish at low RPM
Hey Folks,
Just replaced my timing belt on a 5sfe but the problem now is, it’s sluggish at low RPM’s. Is it possible that it skipped a tooth. I made sure that the TDC is correct. It feels like turbo lag but without the turbo. Should I advance the timing? Any help would be great.
Greaper_ca is offline   Reply With Quote
Old 08-01-2008, 02:21 AM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Eek, you might just be off by a tooth. Back in the day I had a turbo Talon, and when the t-belt skipped a tooth the symptoms were similar to those you're describing. Have you re-checked your timing?
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 08-09-2008, 08:02 AM   #3 (permalink)
Thanks Tbay,
Looks like I did skip a tooth. The cars working fine now.
Old 08-29-2008, 11:04 AM   #4 (permalink)
View kelcey's Photo Gallery
out of curiousity did your car start and idle good ? And also run good after 2000 or so rpms?
I think I have the same problem
kelcey is offline   Reply With Quote
Old 10-05-2008, 09:20 AM   #5 (permalink)
Sorry for getting back late.
Yes it did start but did not idle good. I found that I skipped a tooth when replacing the timing belt.
