92 Celica - How to replace an antenna? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2008, 12:50 AM   #1 (permalink)
View mugz's Photo Gallery
I need to replace the antenna on the car, but before I bid on something like that on eBay, I would like to ask someone, how would I remove this from the car? The old Antenna is ripped out, some one just tore the thing off. All I see is a silver rim and a small hole on the trunk.
Any ideas?
Thank you
mugz is offline   Reply With Quote
Old 08-07-2008, 01:14 AM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
The antenna unbolts from the inside of the hatch/trunk--just remove the plastic trim to gain access. As for the exterior, there should be a threaded keeper on top of the base, you can unscrew that to allow the antenna mast (or what's left of it) to drop through the hole and into the trunk area. Hope this helps...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 08-10-2008, 01:58 PM   #3 (permalink)
Blane's Avatar
View Blane's Photo Gallery
mine was a pain to remove I had to use bolt cutters because everything was corroded solid. Be careful I screwed up my paint a little when I replaced mine with a rubber antenna. Looks sweet!
Blane is offline   Reply With Quote
