Fuel Filter 2000 Celica - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-08-2008, 12:06 PM   #1 (permalink)
View lerio27's Photo Gallery
Does anyone knows where the Fuel Filter is located? I have a Celica 2000 gts model. I need to know because I have my engine check light on, and it says lean on a bank 1, which I figured that it may be the oxygen sensor. It had a code po171 on my OBI data. I changed the fuel filter sensor on the bank 1, but problem still exists.
lerio27 is offline   Reply With Quote
Old 08-11-2008, 11:08 PM   #2 (permalink)
Electromagnetic Wave [:-h
2way's Avatar
View 2way's Photo Gallery
??? I think your quite confused.
To answer your question, the fuel filter is in the fuel tank on the pump.
A P0171 is often a vacuum leak, dirty MAF sensor, or a bad O2 sensor.
Fuel filter sensor on Bank 1??? I'm assuming you mean the O2 sensor?
'02 Celica GT-S/6 '96 Avalon XLS
'88 Camry DX Wagon '86 Camry DX Sedan '83 Corolla SR5 Liftback Wagon '82 Ford LTD-S(351W HO) '79 Corolla SR5 Sport Coupe '76 Corolla Wagon
PCIA Certified Mobile Communications Technician
2way is offline   Reply With Quote
Old 08-12-2008, 05:02 AM   #3 (permalink)
View tommy8768's Photo Gallery
You need to clean or replace your MAF sensor.
tommy8768 is offline   Reply With Quote
Old 08-12-2008, 12:20 PM   #4 (permalink)
6th gen master
View hatchy_gt-s's Photo Gallery
to go into to more detail
first let me start off with this
Bank 1/2 stands for exhaust manifold 1 or 2 (1 being the side that has cylinder 1 on it)
sensor 1/2 means your pre/post-cat, sensor 1 reading pre and 2 reading post
a bank 1 sensor 1 means your pre-cat o2 sensor and it reads your fuel to air mix and with a lean condition that means its not reading enough fuel which is either to much air or to little fuel and going with the fact that the new celi's have problems with there MAF i would have to say thats your fault.
and o2's rarely go out.
as for the bank 1 sensor 2 reads the hydrocarbons/emissions coming from the cat
hatchy_gt-s is offline   Reply With Quote
