1990 Celica's flashers-turn signals not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2008, 09:16 PM   #1 (permalink)
View tvmaster's Photo Gallery
I have a 1990 Celica ST coupe. The left flasher started to go at double speed, and when I was changing the bulb, there was a small spark and then the flashers, front and back, died for good.
The headlights, hazards and running lights still work.
I checked all the fuses I could find in the engine compartment, but to no avail.
Anyone have any ideas what's gone wrong?
thanks
tvmaster is offline   Reply With Quote
Old 08-21-2008, 02:50 PM   #2 (permalink)
View toyomoho's Photo Gallery
You checked all the fuses including the Turn signal fuse? There may be a fuse box behind the drivers side dash, about where you left knee would be, also drivers side kick panel.
Try www.autozone.com for location info, the site has a good self help repair section.
Find and replace the trun signal flasher, might be behind the drivers side kick panel.
Old 08-21-2008, 07:41 PM   #3 (permalink)
thanks - I found the second fuse panel, and sure enough, the turn signal 10 amp was fried. However, I still have the problem of the left signal flashing too quickly - so the next question is: bulb socket or relay?
thanks
