2000 celica gts overheating... help please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2008, 11:55 AM   #1 (permalink)
View bayron13's Photo Gallery
okay so my celica overheated and i just replaced the thermostat but when i start it and try to put antifreeze in the little catch can it won't go down, water doesnt seem to be going thru the hoses and it still overheats, the heater doesnt work either....
bayron13 is offline   Reply With Quote
Old 08-23-2008, 07:41 PM   #2 (permalink)
View toyomoho's Photo Gallery
Not up on this car, what is the "little catch." Does it have a radiator cap?
Did the engine overheat before the T-stat change?
Did you install the T-stat with the spring inside the cylinder head or toward it?
Try squeezing the radiator hoses to get some of the air out.
If you don't think the coolant is circulating take out the T-stat, fill with distilled water then determine if the water circulates. If not look for clogged radiator, hoses, bad water pump.
Old 08-23-2008, 09:37 PM   #3 (permalink)
"Circle of trust"
View catric69's Photo Gallery
Also make sure you are using the proper Toyota coolant. Here are coolant bleeding procedures for the celica.
http://www.newcelica.org/forums/showthread.php?t=192777
catric69 is offline   Reply With Quote
