2SE Starved for Air
'86 Celica GT, w/ 2SE, Automatic Trans, New Timing Belt w/ 1800 miles on it, new Water pump, new Distributer -Last Week it began Idling rough, surging and sputtering, checked the timing and adjusted idle per manual, changed fuel filter. Changed the Plugs and installed new Remanufactured air sensor. Checked the Throttle Position Sensor, as well as all the Water Temp sensors, and the Air Valve. The only way it will run smoothly is if I leave the air filter box lid off, cracked about 3/4 to 1" open. It runs too fast then and is using too much gas like this. I can't figure it out. The "Check Engine" light is not on, but I tried to pull codes anyway, no code... What have I missed? Anybody have any clue what is going on?
