clutch issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-04-2008, 12:59 AM   #1 (permalink)
druski79's Avatar
View druski79's Photo Gallery
clutch issues
i got a 86 st replaced the clutch, once the car is warmed up, the clutch grinds in 2nd. but only when i down shift. Someone told me tranny issues but not sure. Also is sluggish in 1st but i think that has too do with either my timing or fuel system. When i let off it back fires. Anything will help because i need to sell to buy a truck for work. thanks for looking.
druski79 is offline   Reply With Quote
Old 09-06-2008, 10:51 AM   #2 (permalink)
Blane's Avatar
View Blane's Photo Gallery
the grinding issue is a problem with the syncros. the other problems is a timing issue with the engine
Blane is offline   Reply With Quote
Old 09-06-2008, 11:28 AM   #3 (permalink)
just a nobody
Did you change the fluid in the transmission? Put in the right fluid?
N.E.O.
Old 09-06-2008, 11:03 PM   #4 (permalink)
druski79's Avatar
Do i have too rebuild the trany to replace the syncros? thanks for the advise and we replaced the trans fluids, had the same thing happening before the new clutch went in. I will get the timing looked at maybe off a tooth or two. Thanks again Drew.
Old 09-06-2008, 11:45 PM   #5 (permalink)
just a nobody
You do have to disassemble the transmission to replace syncros. I had been told, but I haven't try it myself or experience it first hand, Redline manual transmission fluid can help with minor sticky syncro problems in manual transmission.
N.E.O.
