How do you remove speakers - 1990 ST coupe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2008, 12:13 PM   #1 (permalink)
View tvmaster's Photo Gallery
I have a 1990 Celica ST coupe with stock speakers (2 in the dash and 2 in the rear seat panels).
Does anyone have a schematic or diagram on the proper removal technique?
I'd hate to hack something that wasn't meant to be hacked.
Final goal is to put in four, better speakers.
thanks
tvmaster is offline   Reply With Quote
Old 09-11-2008, 12:45 PM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Front speakers are mounted to the inside of the dash panels. Remove phillips screws under steering wheel, and around glove box to remove. Rear speakers are hidden behind metal screen garnishes. Gently pry forwards and out at rear of covers to "pop" them off. Inside are four phillips screws to begin removing the side trim panel. Remove bench seat and unscrew one more phillips screw at bottom of side panel. Carefully pull panel away from the body (at the rear quarter panel) and remove the speaker housing. The speaker is screwed into a large plastic housing, which makes the outer panel removal necessary. All in all, it's a giant P.I.T.A.
The Chilton's manual has really good diagrams, you can probably borrow one at the library to see what I'm referring to...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 09-12-2008, 01:22 AM   #3 (permalink)
Great - thanks for the help so far, I'll take a look in my local library. It sounds a wee bit harder than my Mazda 3.
