ok so it's been a while since i posted in here and i am at a point where i am ready to go ahead with a 1mz-fe conversion into my st184 celica,
ripping out the 5sfe will be an awesome feeling as this one is just about to give up the ghost and i've cut my losses and am refusing to do any more to it just to keep it running as it seems to be a bottomless pit...........
firstly this will be done within the next month or two.......
engine is sourced, shop is sourced to do the making of custom parts,
i will try to keep you all informed of progress if ya all are interested............
research so far indicates...................
1- stock 184 gearbox bolts up, only change will be a modified/custom dust/inspection plate....
2- will need front timing cover side engine mount custom made...
3- the 1mz-fe does not have a return fuel rail so i will be using a 3vz-fe fuel rail..
4- i will also be using the 3vz-fe intake/throttle body as it is mechanical instead of the 1mz-fe's electronic throttle body....
5- new centre bearing mount for cv..
6- ecu i will let the shop deal with that.
7- upgraded fuel pump
8- headers and exhaust system
So far i just intend to do a stock for stock conversion effectively doubling current power output........73kw to 143kw, future plans will include either turbo or supercharger, still usure at this stage, but right now thats not important....
if anyone has any suggestions or maybe something that i have overlooked please let me know......
my reasoning for this conversion is that i get more power, stay legal, still fuel efficient, and alot more fun to drive, and it's a somewhat out of the ordinary conversion for a celica,
