No Headlights fixed tail lights
Hello all,
My headlights and taillights on my 1985 Toyota Celica GT-S are not working. I have checked/replaced all relays/fuses under the hood and in the kick panel.
My turnsignals work my side markers work, my running lights in the front work, my stop lights work, and my headlights pop up. Where should I go from here?
I have been examining a wiring diagram, but I'm scratching my head on this one, as far as the headlights go the circuit is pretty cut and dry. Two fuses (Both good) and a bridge between the two headlights that go to the headlight switch on the steering column. I would figure that since the Head lights still pop up that the switch would be good.
My thinking according to the wiring diagram, the only thing that both circuits share is this "LT Retainer Relay" Where is this located?
