03 Toyota Celice GT problems..
I just purchased a 2003 Toyota Celica GT less than a week ago.
I had it checked out at my mechanics before purchasing and the only major thing they reported it needs is the serpentine belt replaced.
However there are a few things that I've noticed in the short time I've had her that I was wondering how easy/costly to replace either myself or at a mechanic.
1) Driver side window gets jammed/stuck after being rolled down all the way. Rolling it up and down a bit corrects this. I'm not sure if this is related, but whenever I shut the driver side door, I can feel something loose inside the door moving around. I'm not sure if its a component of the window/motor that is causing it to get the window off track or something completely unrelated.
2) Whenever I go to pump up gas, the pump will not go more than a few seconds without automatically shutting off. It doesnt matter how i angle the pump, it'll keep shutting off automatically.
I'm not sure if this is related or not, but either the celica has a very small gas tank or the gauge is off. I'll put about 20 bucks of gas (at 3.15 a gallon) and it will fill it almost 3/4 of the tank.
3) When I'm braking, sometimes there is a loud squeal emitted from the from of the celica. This doesn't occur every time I brake but often enough that I'm worried about it.
I appreciate any help you guys could give me. Thank you!
