2bar mapsenor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2008, 02:02 PM   #1 (permalink)
View silverbullet94's Photo Gallery
Unhappy 2bar mapsenor
Does anyone know where/ to get a 2barmap sensor.
Just turboed a 5sfe celica gt and clearly need a map sensor to read the more dense air.
I called a dealership and asked about getting one from a 93 celica 3sgte,
but the guy said that he thinks the part number is 8942020140, and it will cost $392 but hes not sure its the right part.
Clearly not gonna spend 392 on a special order part and have it not solve the problem.
Where can I get it/ what should I tell the parts guy (if they carry that)
silverbullet94 is offline   Reply With Quote
Old 10-16-2008, 03:47 PM   #2 (permalink)
View concealer404's Photo Gallery
GM 2bar sensor is fine, too.
1993 Celica GT Coupe (sold w/ 218k miles)
1992 Celica GT Hatch (The new $600 hotness.)
1993 Escort GT ( i have a thing for GTs.) POWERED BY MAZDA B-SERIES
concealer404 is offline   Reply With Quote
Old 10-16-2008, 07:19 PM   #3 (permalink)
do you know if there an easy switch? I think I might just get the one from the dealer, another forum told me that that is the partnumber for the 3sgte 2 bar map sensor I am looking for.
do you know if my stock ecu will be able to compensate for that pressure change?
my wastegate is set at 7lbs which is only 1 bar... the ecu can interprete that information?
Old 10-17-2008, 03:22 PM   #4 (permalink)
Your ECU, being map-based, will read the information from whatever map sensor is on the car, and adjust for it. To a point. I would efinitely not suggest just running your car with a 2bar, stock ecu, and nothing else. (Although this is how the old Burien turbo "kit" worked.)
MSD BTM, maybe an E-manage would be a good place to start.
Old 10-20-2008, 12:14 PM   #5 (permalink)
that was actually my next step, thanks for the heads up. with the MSD 6 BTM I should have the timing set to the original 10 degrees right?
Old 10-22-2008, 12:40 PM   #6 (permalink)
Couldn't tell ya, to be honest. All i know is that it retards timing based on pressure.
I haven't used one. The only non-turbo cars that i've messed with turbos on are Hondas, and i just tune them with Crome.
Old 10-24-2008, 05:26 PM   #7 (permalink)
I have the ge 2 bar map sensor do you know what A B and C terminals are the wires im connecting to are Brown: ground, Green-brown: power, and the Red:VC... which wire goes to which terminal?
