Shift knob not shifting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2008, 08:21 PM   #1 (permalink)
View donwonbelieves's Photo Gallery
I can't switch in and out of gears. I think that I am stuck in second of third. I checked the cable and they are al connected. Could they have gone bad, or is ther something else I should take look at. The knob has no play what so ever.
donwonbelieves is offline   Reply With Quote
Old 10-27-2008, 12:33 AM   #2 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
Check the easy stuff first: fluid level, then the slave cylinder.
Rick89GTS is offline   Reply With Quote
Old 10-27-2008, 12:01 PM   #3 (permalink)
View donwonbelieves82's Photo Gallery
Fuids are good, I was thinking that it might be the shift cables going bad but I can't find any to buy. They are still connected. This is a manual 5 speed 1.6L Celica St. When the clutch is fully engaged nothing change. It's like the knob moves but it can't find a hole.
donwonbelieves82 is offline   Reply With Quote
Old 10-30-2008, 08:17 PM   #4 (permalink)
View Puffie40's Photo Gallery
sounds like broken shifting cables. disconnect one end of the cable and give it a tug.
Puffie40 is offline   Reply With Quote
Old 10-31-2008, 07:57 AM   #5 (permalink)
your said one end, do you mean the end that is hooked to the tranny. And what am I looking for when I tug on it. Also does anyone know where I can get a new set of these cables.
Old 10-31-2008, 11:37 AM   #6 (permalink)
If the cables are indeed broken, pulling on one end will pull the inner cable right out. if it is fine, you should only be able to move it a few inches.
Toyota should have those cables if no one else does.
