Help! O2 sensor problem. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2008, 04:05 AM   #1 (permalink)
View James_LL's Photo Gallery
Hey all,
I just installed a pod filter on my 1989 Celica, pulled the air box out, attached the pod filter to the o2 sensor and clamped it. Now it wont start.
When i pulled off the air box i disconnected the o2 sensor plug about a cm then plugged it back in. It looks like its just a pin connecting, maybe soldered.
Does anyone have any idea why the air sensor isn't responding now?
Help much appreciated!
Cheers.
James_LL is offline   Reply With Quote
Old 11-02-2008, 12:12 AM   #2 (permalink)
6th gen master
View hatchy_gt-s's Photo Gallery
ok well first its not an o2 sensor, o2 sensors are in the exhaust, what r u talking about when u say clamped the sensor to the filter
ok you have a air temp. sensor which reads the air temp using a heated wire, the cone filter is an oil based filter and will cause the air temp sensor to over heat causing problems.
hatchy_gt-s is offline   Reply With Quote
