92 Celica Skipping - Need Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2008, 08:04 AM   #1 (permalink)
CBUL0131
View cbul0131's Photo Gallery
Car is GTS, 4 cylinder. Started skipping last week. Replaced all four spark plugs, did compression check and all 4 cylinders show 250 pounds of compression. Cylinder number four is firing but plug is not. When you pull the wire off #4, the car continues to idle. Would appreciate any suggestions on what to try next. Thanks!!
cbul0131 is offline   Reply With Quote
Old 11-03-2008, 09:43 AM   #2 (permalink)
CBUL0131
1992 Celica Skipping
My prior post was incorrect in that the wire and plug on cylinder #4 are both firing, the cylinder is not firing. Could this be a gas problem?
Old 11-03-2008, 05:49 PM   #3 (permalink)
jlspec's Avatar
View jlspec's Photo Gallery
If you are sure that the number four is firing then it's part of your fuel system that has gone wrong. Check your injector and fuel lines.
1990 Celica Turbo All-Trac
jlspec is offline   Reply With Quote
