i goofed help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2008, 10:38 PM   #1 (permalink)
View celica2202's Photo Gallery
i goofed help
i goofed up and i dont know how
we did a headgasket change and somehow the engine runs but the throttle works oddly
when its reved the engine slows till it sputters and it has a really low idle
also before some tinkering it would rev to redline then idle then rev and idle over and over
what did we do wrong?
celica2202 is offline   Reply With Quote
Old 11-10-2008, 12:46 AM   #2 (permalink)
just a nobody
It could be anything, you just have to go in and inspect all the work that was done, and compare it with a manual if you have one. Check the wiring harness and connection to make sure everything is connected to where they should be.
BTW, what year and engine?
N.E.O.
Old 11-10-2008, 05:53 AM   #3 (permalink)
its a 90 gtand its got a 5sfe motor in it
Old 11-18-2008, 02:09 AM   #4 (permalink)
View Freshnicity's Photo Gallery
Could be a compression problem? just taking a stab at this...i know im 7 days late.
Check the compression, if the head gasket isnt properly replaced, you could be losing compression.
Also, did you replace the torque-to-yield bolts on that gasket?(you cant reuse those bolts, if you did, go replace them my friend).
Freshnicity is offline   Reply With Quote
