99 Celica Plug Boot Leak? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2008, 07:32 PM   #1 (permalink)
View carlr33's Photo Gallery
I have a 99 Celica GT convertible with 155K miles that has started to leak oil on the top of one of the plug tubes. I took out the plug wire and only oil on the top not the bottom. It is the one in front of the PCV valve drivers side 1st cylinder. I replaced the PCV valve thinking that was it but the leak reappeared. Is this an DIY job or expensive for a shop to repair. I did a search and found some info about tube leaks on other models. Thanks
carlr33 is offline   Reply With Quote
Old 11-11-2008, 09:02 PM   #2 (permalink)
just a nobody
Probably need spark plug tube seals. May want to reseal the valve cover and replace the plug wires too if they are original.
N.E.O.
Old 11-12-2008, 02:18 AM   #3 (permalink)
View PittsburghCeli's Photo Gallery
I have the same problem with oil on top of one of the spark plugs. Like NEO said we have to remove the valve cover and repair the tube. I have had my valve cover off before but depending on where the leak is from like the side of the tube or the bottom, I am not sure how easy it will be to fix. JB weld, rtv silicone or replacement parts?
91 Celica GT Coupe
Knowledge builds confidence.
PittsburghCeli is offline   Reply With Quote
Old 11-12-2008, 02:27 AM   #4 (permalink)
just a nobody
If the oil is just around the top portion of the wires, just the tube seals should be sufficient, if it is on the spark plugs and not much on the top portion of the wire, then the tube will need to removed to reseal. However, whichever needs t be done, valve cover gasket would be a good idea.
N.E.O.
Old 11-12-2008, 06:38 AM   #5 (permalink)
Yes, thanks for the replies. Just wondering if the top tube seals can be removed and replaced via removing the nut without completely removing the valve cover? Thanks again
N.E.O.
Old 11-12-2008, 10:19 AM   #6 (permalink)
just a nobody
Yes, you can replace just that one seal; however, it doesn't real take very much more to replace the valve cover gasket. But it is up to you to decide.
N.E.O.
Old 04-22-2009, 05:17 PM   #7 (permalink)
View 90celica's Photo Gallery
What would happen if you do not fix this problem? could it become so bad that it prevents spark?
1990 Celica GT - work in progress
1994 Tercel
90celica is offline   Reply With Quote
Old 04-22-2009, 06:17 PM   #8 (permalink)
Just lose a little oil and compression, that is all. The oil is on top of the plug, and does not make it down past the threads to the electrode.
91 Celica GT Coupe
Old 04-22-2009, 06:18 PM   #9 (permalink)
Just lose a little oil and compression, that is all. The oil is on top of the plug, and does not make it down past the threads to the electrode. There is a special $60 tool sold for tightening the tubes or a pipe wrench is possible.
91 Celica GT Coupe
Old 04-22-2009, 09:47 PM   #10 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
i think we have all done this its really simple^
be ready for a alternator mine went at 150k
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline   Reply With Quote
