Turbo issue. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2008, 04:32 PM   #1 (permalink)
Rockin the Civic
92celicafreak's Avatar
View 92celicafreak's Photo Gallery
Turbo issue.
Ok guys took intake off and found the problem.... I have a broken fin on the inlet side? What causes this?
92celicafreak is offline   Reply With Quote
Old 11-24-2008, 05:44 PM   #2 (permalink)
Rockin the Civic
To add to it now. I disconnected the battery and now i cant role windows up or anything when i hooked it back up and suggestions?
Old 11-24-2008, 08:45 PM   #3 (permalink)
Rockin the Civic
Bump....
Old 11-25-2008, 03:09 AM   #4 (permalink)
engineer in training
Gameroom cash: $141655
Wow, oil starvation is a possibility on the turbo. If the bearings fail excess play will allow the compressor wheel to contact the housing resulting in the destruction of the compressor.
Electrical issue sounds like a bad connection or a blown fuse, check all your grounds and fuses.
Old 11-25-2008, 10:13 AM   #5 (permalink)
Rockin the Civic
K the turbo was rebuilt about 4 months ago. Pretty sure its been good on oil. What if oil had been overfilled once? Not too much but little bit?
Old 11-25-2008, 05:09 PM   #6 (permalink)
No, if the overfilling caused a problem it would be smoking all over the place. You would know something wasnt right...
Old 11-26-2008, 01:26 PM   #7 (permalink)
Rockin the Civic
4th Generation Damge.
Here is some pictures of turbo and stupid IC pipe. Also where can i get couplers?
Damaged Turbo.
Intercooler Piping
Intercooler Piping
Old 11-26-2008, 02:01 PM   #8 (permalink)
ouch, yeah the whole thing will need another rebuild most likely sorry man. Go with a t3/t4 conversion, you will love it and it's way cheaper.
Old 11-26-2008, 03:18 PM   #9 (permalink)
Rockin the Civic
Looking to go 20g upgrade....
Old 11-26-2008, 03:23 PM   #10 (permalink)
Rockin the Civic
Makes me mad. I just rebuilt it 4 months ago bearings are still good and everything.
Old 11-27-2008, 09:46 PM   #11 (permalink)
View aaronwt's Photo Gallery
May be it sucked some small stones you have to change the fins then again.
aaronwt is offline   Reply With Quote
Old 11-30-2008, 01:53 AM   #12 (permalink)
Bearings are fine? Weird, I just haven't seen enough turbo failures to try and guess any more on this. 20g will be an awesome upgrade!
Old 11-30-2008, 01:02 PM   #13 (permalink)
Rockin the Civic
But is 20g worth the money?
Old 12-01-2008, 11:40 AM   #14 (permalink)
View concealer404's Photo Gallery
Compared to what?
1993 Celica GT Coupe (sold w/ 218k miles)
1992 Celica GT Hatch (The new $600 hotness.)
1993 Escort GT ( i have a thing for GTs.) POWERED BY MAZDA B-SERIES
concealer404 is offline   Reply With Quote
Old 12-09-2008, 08:50 PM   #15 (permalink)
View Octapulse's Photo Gallery
Are you using a blow-off valve? If not, that could put alot of stress on the turbo because when the throttle snaps shut, the trapped air will try to escape back through the turbo. I dont know if this could have possibly caused what I see, but never the less a turbo set-up without a blow-off valve is not a good idea. If you dont have one and you plan on installing one, you will want to recirculate the blow-off back to the intake (past the MAF sensor) so that the metered air stays in the sytem (otherwise your air/fuel mixture will get messed up).
Octapulse is offline   Reply With Quote
