Rims for an '89 Celica - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2008, 10:51 PM   #1 (permalink)
View ecalamity's Photo Gallery
I have a 1989 Celica and was wondering if I can put rims with these specs. - 195/55/15. Also, I would like to know if I would need any extras for it to fit without having it rub against anything. For example, getting wheel spacers.
ecalamity is offline   Reply With Quote
Old 11-30-2008, 03:09 AM   #2 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
195-55-15 is fine just as long the offset is close to +39mm, that's the factory offset.
To give you an idea, on my 89GTS I ran 205-55-15's on 15" x 7" rims with +40mm offset, but needed a 5mm spacer, otherwise it rubbed the rear struts.
EDITED: 5mm spacer, not 45mm spacer!
Rick89GTS is offline   Reply With Quote
The Following User Says Thank You to Rick89GTS For This Useful Post:
ecalamity (09-07-2011)
Old 11-30-2008, 02:03 PM   #3 (permalink)
Gg. Alrighty then, Ty ty.
Old 11-30-2008, 05:31 PM   #4 (permalink)
View PittsburghCeli's Photo Gallery
I am running those right now on my 5th gen with no problem. I think a 205 will rub and you would need wheel spacers.
91 Celica GT Coupe
Knowledge builds confidence.
PittsburghCeli is offline   Reply With Quote
The Following User Says Thank You to PittsburghCeli For This Useful Post:
Old 12-01-2008, 04:09 AM   #5 (permalink)
RA28 + MX73
View stepho's Photo Gallery
Avoid wheel spacers - they are prone to breaking wheel studs.
Better to get the correct offset or use the narrower tyre.
-Stepho
stepho is offline   Reply With Quote
The Following User Says Thank You to stepho For This Useful Post:
Old 12-03-2008, 01:20 AM   #6 (permalink)
Rick89GTS's Avatar
5 or 8mm spacers don't make much difference in day-to-day driving. If you're very aggressive or performance driving, yes, you may want to get longer wheels studs or go to the bolt-on spacers but they are more $$.
