low rpm idle at startup - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2008, 06:27 PM   #1 (permalink)
View PittsburghCeli's Photo Gallery
Gen5 low rpm idle at startup
Recently when I start my car, it starts fine when it's cold because it will idle high until it warms up, but if I start it while it's warm the rpms drop to about 500 barely idlling and if I tap the gas a couple of times the problem goes away and it idles normally at about 700.
I recently also replaced the o-ring on the distributor because it was leaking oil. I reset the timing twice. It is hard to get an accurate reading in the dark, looking at a little timing mark 3 feet away, but I am sure it is at 10 BTDC.
New wires, new thermostat, air filter could be a little dirty, other than that, I am thinking it might be an oily sensor or something else?
91 Celica GT Coupe
Knowledge builds confidence.
PittsburghCeli is offline   Reply With Quote
Old 06-19-2011, 02:15 AM   #2 (permalink)
FNG
View GTcelica22's Photo Gallery
i know this a really old post but did you ever find what was wrong with your car? i'm having the exact same problem and every other thread i find with this problem is incomplete with no resolution.
GTcelica22 is offline   Reply With Quote
Old 06-23-2011, 02:24 AM   #3 (permalink)
PEN
PEN's Avatar
View PEN's Photo Gallery
Hey bro I'm new to this kinda car but know a good bit of things about cars in general.
Some causes:
*IAT sensor (on the intake tube it plugs into the intake)
*dirty injectors (not too likley)
*your car in ur sig looks turbo'd so check for loose pipes/intake or anything, happened to my turbo car ran some crazy rpms randomly
*more than not its something loose like your intake or a sensor starting to go bad
Hope this helps a bit.
Cheers to a nicely tuned car m8
PEN is offline   Reply With Quote
