92 Celica temp.control problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2008, 07:50 PM   #1 (permalink)
View uphogger's Photo Gallery
USA 92 Celica temp.control problem
Does anyone know what controls the temp.control valve on a 92 GTS? I verified that the valve does work but it either goes all the way hot or the all the way cold,nothing in between.When I turn the knob a 1/4 past cold,the control valve will go completly to hot.
uphogger is offline   Reply With Quote
Old 12-09-2008, 08:00 PM   #2 (permalink)
View PittsburghCeli's Photo Gallery
Heater problem
Check the thread above. Seems there is a valve and a flap. I would say the valve should go on all the way when just a little heat is selected, but the flap should only work in conjunction with the heat dial, but I could be wrong. My heat still doesn't work right but I have to check a couple things.
91 Celica GT Coupe
Knowledge builds confidence.
PittsburghCeli is offline   Reply With Quote
