Coolant Bypass, high idling issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2008, 08:27 PM   #1 (permalink)
View Freshnicity's Photo Gallery
So i did the coolant bypass on my 92 ST, all went well, except now its idling high, like almost 2krpm's high. And when im driving it, and put it in nuetral while the cars moving, the idle shoots up and down from 1k-2krpms, then when i come to a full stop, it stops at 2krpms.
How do i fix this stupid issue?
http://www.ultimateresourceguides.c...a-freemods.html
^instructions i followed
Freshnicity is offline   Reply With Quote
Old 12-16-2008, 09:45 AM   #2 (permalink)
View concealer404's Photo Gallery
Vaccuum leak or faulty IAC valve.
1993 Celica GT Coupe (sold w/ 218k miles)
1992 Celica GT Hatch (The new $600 hotness.)
1993 Escort GT ( i have a thing for GTs.) POWERED BY MAZDA B-SERIES
concealer404 is offline   Reply With Quote
Old 12-16-2008, 11:44 PM   #3 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
Not sure what mod you did (and I'm too lazy to read the link), but check your coolant level. On the ST162 and ST165, if the coolant is too low, the revs will cycle from 1,000 to 2,000 constantly.
Rick89GTS is offline   Reply With Quote
Old 12-17-2008, 01:05 AM   #4 (permalink)
just a nobody
Doesn't the ST have a 4a-fe? The 4a-fe uses the auxiliary air valve for fast idle and the coolant that circulate it warms it up to close off the passage to drop down to warm idle.
N.E.O.
Old 12-25-2008, 02:15 PM   #5 (permalink)
View damp's Photo Gallery
i have the exact same problem on my 90gts, i noticed i put some coolant in the rad, and the rpms stoped bouncing up and down but still revs high. Ill add more today but did you fix the problem on you celica yet so i have an idea of what it is. thx
damp is offline   Reply With Quote
Old 12-26-2008, 01:16 AM   #6 (permalink)
Rick89GTS's Avatar
^On my Celica it's fine now.
You may have an air pocket in your system. "Burp" the system and it should be OK.
