1990 celica rod knocking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-23-2008, 10:42 AM   #1 (permalink)
View jeffhamil's Photo Gallery
I have what I believe is a rod knocking. The car was run low on oil. It is a 1990 celica st with a 1.6. The car is very stock. Do I replace the engine or rebuild it. I would like to try and get a little bit more power if possible. This will be done on a budget, and most likely by me. What do you think?
jeffhamil is offline   Reply With Quote
Old 12-23-2008, 11:22 AM   #2 (permalink)
View toyomoho's Photo Gallery
If a rod knocking the crank bearing journal may be damaged from the hammering. You might be able to grind the crank under size but will first need to check the damage.
Old 12-23-2008, 12:20 PM   #3 (permalink)
View concealer404's Photo Gallery
Just grab another 4afe bottom end out of a junkyard.
Not worth rebuilding, not worth rebuilding for more power.
If you want more power, swap the car to a 20v 4age.
1993 Celica GT Coupe (sold w/ 218k miles)
1992 Celica GT Hatch (The new $600 hotness.)
1993 Escort GT ( i have a thing for GTs.) POWERED BY MAZDA B-SERIES
concealer404 is offline   Reply With Quote
Old 12-23-2008, 06:09 PM   #4 (permalink)
Blane's Avatar
View Blane's Photo Gallery
I had two 4afe engines die due to the same sort of problem. Both engines had a stuck lifter that sounded horrible like a severe rod knock. Get a whole working engine it's not worth fixing.
Blane is offline   Reply With Quote
Old 12-30-2008, 02:59 PM   #5 (permalink)
Thanks, is the 20v 4age a fairly simple swap
