harness
there's a special harness that comes with 2 rca ,are u planning to change the factory amp thats located behind the glov..box passenger side ,if yes u dont need no harness ,yellow /w stripe is power,brown is ignition and black is ground ,the only 3 u need , i dont think toyota ever change there colours ..
if u going change just radio u will need that harness ,there's a place in bridgeport ct that has that harness its called sounds good , located on park ave ..
however u will need to locate the factory amp if your car carries one ,if not just tap into the harness and u good to go...
if amp is present ,u will need a 9volt bat to touch the wires off the amp harness to see left from right , and front from rear... the harness is a bit tuff to realy get to ,careful not to damage it or else u f....
the colours changes due to some models come with jbl systems..
good luck ....
