will my tires fit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2009, 09:56 PM   #1 (permalink)
View helena's Photo Gallery
will my tires fit
i tried to find tires for my 89 celica(205/60/15)no luck anywhere.i had to settle with 205/70/15, will this work on my car?i know it will throw off my speedometer.
helena is offline   Reply With Quote
Old 01-07-2009, 12:03 PM   #2 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
Gen5 might not affect
it might not throw off the speedo mine came stock with 15ish steel wheels with the moast unstylish hub caps then i got a set of 16 alloy wheels and now i have the 17 scion tc low profile wheels on it i took a handheld gps with me and its dead on balls accurate (they doo rub a tiny bit when the wheel is all the way over)
asphalt victory is offline   Reply With Quote
Old 01-07-2009, 05:16 PM   #3 (permalink)
"Circle of trust"
View catric69's Photo Gallery
should work on your car and will throw off your speedometer. 195-65-15 will be a better size for you application.
catric69 is offline   Reply With Quote
Old 01-07-2009, 05:56 PM   #4 (permalink)
Bdub215's Avatar
Gameroom cash: $317765
View Bdub215's Photo Gallery
ever heard of tirerack.com??
93 Lexus ES300 5spd I/E URSB
Bdub215 is online now   Reply With Quote
Old 01-13-2009, 01:39 AM   #5 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
1989 came with 205/60/14 stock.
Do you have a JDM 1989, which is a 5th Gen (not a 4th Gen; North America)?
Rick89GTS is offline   Reply With Quote
Old 01-27-2009, 11:52 PM   #6 (permalink)
ya, it turns out I couldnt get the tires because they dont make that size anymore.I could have ordered them but I had a flat and needed them NOW.So I went with the suggested size.Thanks for the help.
Old 01-28-2009, 12:56 AM   #7 (permalink)
just a nobody
Bdub215 suggested tirerack.com: http://www.tirerack.com/tires/Compar...=1&RunFlat=All
N.E.O.
Old 01-28-2009, 08:50 AM   #8 (permalink)
View concealer404's Photo Gallery
wut
You do realize that wheel diameter has no bearing on speedo accuracy, right?
1993 Celica GT Coupe (sold w/ 218k miles)
1992 Celica GT Hatch (The new $600 hotness.)
1993 Escort GT ( i have a thing for GTs.) POWERED BY MAZDA B-SERIES
concealer404 is offline   Reply With Quote
Old 02-15-2009, 11:44 PM   #9 (permalink)
View slayaplaya's Photo Gallery
omg someone cut that guy the size of the wheel diameter will effect the speedo reading...FACT
slayaplaya is offline   Reply With Quote
Old 02-16-2009, 08:38 AM   #10 (permalink)
christine_lives!'s Avatar
View christine_lives!'s Photo Gallery
Only if the overall diameter of (wheel + tire) changes. If you are getting larger wheels, you can adjust the tire size so overall diameter is the same, and speedo will not change. If you do not adjust, sure, speedometer will be way off.
Just make a proper conversion based off your OEM size.
http://www.tirerack.com/tires/tirete...currentpage=34
christine_lives! is offline   Reply With Quote
Old 02-17-2009, 08:54 AM   #11 (permalink)
Sure.... if you're that guy that just keeps the same profile tire when you upsize your wheels. Which you shouldn't do.
So....
FICTION.
I have 16 inch wheels on my 92 GT that came with 15s. Care to tell me exactly how my speedo reading is affected?
Old 02-17-2009, 08:55 AM   #12 (permalink)
Might find this handy, too.
http://www.miata.net/garage/tirecalc.html
I love this tool.
Old 02-17-2009, 03:27 PM   #13 (permalink)
you guys are so silly everone knows that the speedo works via a 99 cent wirly gig you get at at the checkout line in wal mart lol
Old 02-17-2009, 03:51 PM   #14 (permalink)
I've not tried a whirly gig on my speedo while swimming. I might get some better reactions!
Old 02-17-2009, 04:34 PM   #15 (permalink)
I wear my speedo to walmart all the time.
