95 Celica fuel pump relay location?
I had a new clutch installed a few months ago and I have always noticed that from 1st to 2nd there is a feeling of no clutch for a few seconds.(Similar to the no pedal, no resistance feeling you get when air in lines) and it continues on fine. I have noticed if I slow down to say 20mph for a light and then the light turns green and I try to continue from second gear, their is nothing, no pedal, no noise, nothing and then I have to shift back to first and pray. Yesterday I came back from a 200 mile trip and slowed down shifting into 2nd and then tried to proceed in 2nd at 20mph and car started jerking and lost power so I pulled over. Car idled o.k. in neutral but if I pushed clutch in it started to stall.and giving it gas there was no response. I waited 5 mins and tried to start again, it started, I gave it gas, started to move o.k. about 20 ft and died again so I got towed home. Went out this morning and all is fine. Is there a problem related to long trips and the clutch getting hot? Any help would be great. Thanks.
Reason: Not the clutch
