93 Celica Speedometer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2009, 12:19 PM   #1 (permalink)
View thomas6112's Photo Gallery
Well, my spedometer stopped working after I had to slam on my brakes to prevent from hitting a dog.... Does anyone have any trouble shooting steps I can use so that I'm not just shooting in the dark buying a 200$ speed sensor?
thomas6112 is offline   Reply With Quote
Old 01-14-2009, 12:48 PM   #2 (permalink)
View concealer404's Photo Gallery
It's gear driven, not speed sensor driven, so you'd REALLY be wasting your money.
And for the 5th time in the last month, here's how to check... sigh.
There's a cable that goes from your transmission through your firewall to your guage cluster. It's in two parts, one that goes from the tranny up to about.... 8" from your firewall, where it screws into the part that goes through your firewall to your cluster.
1) Check to make sure the cable is tightened down and secure in the tranny. It will only go in a certain way, and if you dislodged it due to vibration or anything else, you'll have to screw it back in. And it's a bitch. Enjoy. Should take about 10-20 minutes of swearing and cramping your arm, it's a really bad angle.
2) If the cable is OUT, make sure that the prong hasn't broken off the bottom of it... if it HAS, go get another bottom section from the junkyard for like... $5. Any manual 5th gen will have the correct part, whether it's ST, GT, or GTS.
3) If the bottom part is correctly inserted and tight, check the connection to the upper cable. Same deal, should be tight and snug. If it IS:
4) Check to see if the cable is properly inserted into your guage cluster. This sucks, i'm not going to tell you how to take the cluster out to check, it's a bunch of screws around the cluster, and then you have to maneuver it out somehow.
1993 Celica GT Coupe (sold w/ 218k miles)
1992 Celica GT Hatch (The new $600 hotness.)
1993 Escort GT ( i have a thing for GTs.) POWERED BY MAZDA B-SERIES
concealer404 is offline   Reply With Quote
Old 01-14-2009, 03:21 PM   #3 (permalink)
Thanx
Thanx a bunch I thought it had a cable but when i went to napa they were like no you need a sensor and I was like YEAH OK! lol I got the cluster thing covered I've taken that thing off multiple times! Thanx alot again! Just when I looked under there after they told me about the sensor I didnt see a cable going to one of the rotors like my truck is set up and now that makes sence! Thanx again!
Old 01-14-2009, 03:36 PM   #4 (permalink)
Napa sells parts... they aren't certified to diagnose cars.
We DO have speed sensors.... but if i said that i've even heard of more than one going out in the last 5 years i've been around the community... i'd be lying.
