Adjust Timing w/out Removing Timing Belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2009, 03:21 PM   #1 (permalink)
christine_lives!'s Avatar
View christine_lives!'s Photo Gallery
For the 5sFE:
I remember reading about adjusting your timing (not just advancing or retarding timing) to TDC without having to remove the belt and all the belt housings. Basically it said you could remove the valve cover and reset the camshaft timing to TDC and tighten it to correspond to the crank TDC. Anyone know what I am talking about. I really don't have the place or space to do a full timing belt job. And besides, i need to redo the valve cover seal anyways and check out the valves and whatnot.
christine_lives! is offline   Reply With Quote
Old 01-22-2009, 07:26 PM   #2 (permalink)
View toyomoho's Photo Gallery
Reset to TDC?
The cams and crank physical timing are set when the belt is installed, there should be no reason to adjust this. There is only one way to setup this relationship and not benefit from changing it.
If you want to change the belt you will need to remove the crank pulley and timing cover.
If your talking about setting the ign timing thought the 5S-FE had a 10 degree BTC setting.
Old 01-22-2009, 08:31 PM   #3 (permalink)
I guess thats my point. I don't want to remove the lower cover, the pulley or the belt. I just wish I could remember where I read about resetting the timing by taking off the valve cover.
Old 01-23-2009, 08:16 AM   #4 (permalink)
View concealer404's Photo Gallery
Yeah.... jump your T1 and E1, and put a timing light on that thing. Set to 10btdc using the distributor.
1993 Celica GT Coupe (sold w/ 218k miles)
1992 Celica GT Hatch (The new $600 hotness.)
1993 Escort GT ( i have a thing for GTs.) POWERED BY MAZDA B-SERIES
concealer404 is offline   Reply With Quote
Old 01-23-2009, 08:36 AM   #5 (permalink)
That would only change the ignition timing. Wouldn't my compression still be off?
Old 01-23-2009, 11:41 AM   #6 (permalink)
Probably.
I didn't understand your question.
Tell us exactly what you're trying to do, what your problem is, and we'll go from there.
Old 01-23-2009, 12:35 PM   #7 (permalink)
I did some minor maintenance when I was home in a garage a few weeks ago:
Timing Belt
Water Pump
Oil Pump
Oil + Tranny Pans
Due to a personal matter, I had to throw it together and book it back to Cincinnati. Picture landlord throwing out your apartment. It ran fine initially, and then the throttle became bogged down. My distributor had a crack in it, thanks in part to my nosey father. The harder it rained, the less response I got. Replaced that, and its really dry outside now. Still no response, running rich, feels like lack of compression when its driven, idles alright until it gets put into a gear. Drops low RPM then normalizes, hasnt stalled.
I'm guessing I am off a tooth or two on the belt. And I remember reading once about adjusting to TDC with the belt on by opening the valve cover. I really dont have the proper place to remove everything to get at the belt. So I'm trying to find a better solution for the time being.
I have to go home this weekend (I have other means of transportation). I suppose I could just tweak the distributor timing a bit with a gun and drive it back. Unless of course someone knows what I am talking about when I suggest cam timing can be adjusted with the belt on. Thanks.
Old 01-23-2009, 12:50 PM   #8 (permalink)
Gameroom cash: $147537
If it was fine when you first put the belt on, the belt could jumped a teeth or two.
Remove top belt cover, turn the crank to 0 deg (match timing mark). Check cam pulley to be at top (small hole on pulley at top of engine, remember engine seat at an angle). If its way off, turn crank another full rev to 0, check again. If you're off, pull belt off cam pulley or pull the pulley out. Use the pulley to turn cam to 0, reinstall pulley and belt. Turn crank a few rev and check again.
The problem is, you might have tensioner too lose so it'll happen again.
Old 01-23-2009, 12:52 PM   #9 (permalink)
View camryvibe's Photo Gallery
If "it ran fine initially" then it's hard to see how the timing belt could have been off by a tooth or two. And it seems unlikely that the belt later slipped unless there's something seriously wrong with its tension. Seems more likely that there's an issue with the ignition timing or possibly something else in the ignition system.
camryvibe is offline   Reply With Quote
Old 01-23-2009, 01:57 PM   #10 (permalink)
Classic case of one of 3 things:
1) ignition problem
2) timing belt slipped via loose tensioner
3) vaccuum leak.
Timing belts slip all the time. But on the other hand... i would think it would KEEP slipping, so i don't think it's that.
I'm sure it's probably ignition timing, because you did mention that you replaced your whole distributor.
Old 01-26-2009, 08:36 AM   #11 (permalink)
The gas mileage is completely deplorable, as it is getting roughly 15-18 mpg. Instead of the usual 28-30mpg.
Started cold, the exhaust blows a wonderfully rich mixture of gas fumes indicating the poor burn. I'll have some time, finally, to look at it again tomorrow afternoon. Architecture school + love of cars + street parking, is not a good equation. I hope it doesn't snow!
Old 01-26-2009, 09:21 AM   #12 (permalink)
Replaced your O2 sensor yet?
Old 01-26-2009, 10:33 AM   #13 (permalink)
The O2 sensor was replaced in December with a Bosch unit. I did clean and replace the sensors (2 to the left of the BVSV and the BVSV) on the cooling out from the block. They were off my old 92' motor, when I had the 93' 5SFE put in. From my understanding the cooling sensors were the exact same on both motors.
Old 01-26-2009, 02:59 PM   #14 (permalink)
If you have a timing gun check timing using the method above.
If the timing is set at 10 degress or you need only more the distributor slightly to adjust the belt location should be OK.
Have you checked the ign coil, these often crack.
A bad coolant sensor can cause problems as the ECU never knows the coolant has warmed up.
Old 01-26-2009, 03:45 PM   #15 (permalink)
Would a bad coolant sensor cause that much poor performance? The temp gauge warms up like normal.
