blow off valve install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2009, 09:59 PM   #1 (permalink)
View celicaturbo's Photo Gallery
Gen5 blow off valve install
does anyone know which vaccum line connects to the blow off valve? im guessing it connects to the intake but im not really sure. can anyone verify this?how much boost can i run on stock internals? I was going to rebuild the 5sfe , but decided not to due to cost and not much gain in hp. im just gonna bolt on the turbo and run it as is until the engine blows.then i will swap a v6 into it (1mz-fe or 3vz-fe) not sure which. it should last for the summer atleast.what v6 engine has the most performance parts?
celicaturbo is offline   Reply With Quote
Old 02-10-2009, 01:15 PM   #2 (permalink)
jlspec's Avatar
View jlspec's Photo Gallery
You'll need one from the intake best near/after the throttle body. If your running stock boost say 5-8psi the 5S-FE should be fine as long as you keep up with maintenance. The power gains should be enough to notice and make a difference. The 5S-FE has a good amount of turq so with the turbo it'll solve your hp department along with adding more turq.
1990 Celica Turbo All-Trac
jlspec is offline   Reply With Quote
Old 02-10-2009, 02:50 PM   #3 (permalink)
View concealer404's Photo Gallery
Stock boost?
1993 Celica GT Coupe (sold w/ 218k miles)
1992 Celica GT Hatch (The new $600 hotness.)
1993 Escort GT ( i have a thing for GTs.) POWERED BY MAZDA B-SERIES
concealer404 is offline   Reply With Quote
Old 02-10-2009, 02:51 PM   #4 (permalink)
What year is your car again?
And why are you boosting a 5sfe for just a summer then going with a V6? Do the work once. Not twice, and save you a good chunk of change.
