Originally Posted by asphalt victory
i was thinking a body repair kit but im worried about it expanding and cracking ill just have to take my time and buy some west system
what is the general consensus with dash paint? nothing tacky like red but like a flat/satin black i mean i dont see how paint can hold to a foam dash. i would like to use some kindof fake leather and kindov re apolster the das/trim
now keep in mind i live about 5 miles away from a strictly all toyota salvage yard im loveing the ideas keep them comming!!!!
You aren't spraying directly on foam..... unless you're missing the plastic cover that goes over and around your entire dash.
There's specific paint for that. You have to prep REALLY well, though, or else it WILL flake. It's in how you do it, not the bonding properties of the product. If it doesn't work, then you screwed up.
You'll want to clean it really good with rubbing alcohol first, then go over it with a scotchbrite pad, and then go over it again with rubbing alcohol. (Removes the cleaners you've been using for years on the dash, which, surprise, are oil based, which makes paint not stick.)
Then do several LIGHT coats until you reach your desired finish.
