The unknown Engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2009, 02:37 AM   #1 (permalink)
View davef413's Photo Gallery
The unknown Engine
I recently blew the engine on my 90 ST celica. It had a 1.6L 4cyl engine in it. I believe a 4aFE. I called a junkyard, and was able to get an engine from a 1993 Geo Prizm. As far as i can remember, the guy only said "it will work with your celica", in which it did. it was a direct bolt, and i have it running.
but... some i have some extra plugs on my wire harness. an orange one near the distributor, and a grey one.
I then came across a post saying that the 1993 prizm came in an "LSi" model with a 1.8L 7aFE engine in it.
how to i tell which engine i have? even though i got the engine i have working, what do these extra plugs on my harness go to? the pic below is of my new engine installed.
even though i have the engine installed and running, i would like to know what kind it is.
also, now my tranny is stuck in first gear.... its an auto. 4speed overdrive i think
any ideas? my friend mentioned a vaulve body... what the hell is that? ha
<img src="http://www.fileden.com/files/2007/9/...42a0a62911.jpg" alt="l_200783b269c042b493287142a0a62911.jpg" />
Also, i had to use my old distributor from my old engine because the new one from the yard didn't work
davef413 is offline   Reply With Quote
Old 02-21-2009, 07:31 AM   #2 (permalink)
Gekko's Avatar
View Gekko's Photo Gallery
Somewhere on the bottom-end of the block the serial of the engine should be carved into it. I thought the serial will always start with the base-id of the engine. So it should start with 4A or 7A.
For the extra wire on the harnass I would suggest that you get a wire-diagram of the Prizm engine and find out on that diagram what the wire is there fore.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you, that's the killer."
Gekko is offline   Reply With Quote
