air in fuel line??????? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2009, 09:57 PM   #1 (permalink)
View broke n busted's Photo Gallery
Question air in fuel line???????
i had to drain and clean my fuel tank to start with. then my efi fuse blew. now my car is hard starting all the time. ive bleed the injecterors, primed my the fuel pump and it still act like there is air in lines. my only other guess is the fuel pump is getting weak. any clue or signs yall now about to tell of fuel pump problems i.e. what it cause the engine to do or act like any help is greatly appreciatd thank you
broke n busted is offline   Reply With Quote
Old 02-22-2009, 03:12 PM   #2 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
does your check engine light come on?
asphalt victory is offline   Reply With Quote
Old 02-22-2009, 06:28 PM   #3 (permalink)
yes also have new fuel pump and filter from previous problem thats turned into this problem
Old 02-22-2009, 11:26 PM   #4 (permalink)
why did you have to drain the tank? i know toyota put the fuel filter in the moast ass spot and it is easy to kink the lines check that...also the gasket around the pump/tank...check the fill hose/conections might have dry rotted or cracked on instalation even the cap has to be spacific.
im not a mechanic but there are people on this cite who might be able to help you better try repoasting
Old 02-24-2009, 07:18 AM   #5 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
What did you do to when you cleaned the tank?
How did you clean it?
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
