ARP Main Head Studs Torque Specs
Whats up guys i have replaced the factory main head bolts on my 3SGTE with ARP studs and my question is what should the studs be torqued at. Currently i have them at 60lbs. Is this correct or incorrect? I already have the engine assymbled but i wanted to make sure before i add fluids if these torque settings were correct. Also i have a Cosmetic Metal Head Gasket...... get at me asap thanks... oooh the engine will be running aroung 12-16psi daily and 20psi when racing thanks.
klone1000
